Toro Personal Pace Mower
PJL1969
That’s what I needed to confirm what engine you have. Engine model number is LEV120 with a Spec number of 361542B. If you are positive you have a good strong battery, I would probably replace these three parts. Gear #34949A, Driver #34946 and Drive Nut #34953. You may only need the driver, but I don’t like having to take it apart replacing one part at a time. Hope this works.
Thanks for your fast responses and valuable information. Very much appreciated.
PJL1969
Thanks again for your help, the parts you recommended are in route but I also need the flange bolts to connect the starter to the motor. Would you know the part number so that I can order those two bolts as well. The engine model # again is LEV120 Spec # 361542B - believe its a Tecumseh starter 38753. Appreciate the help.
No need to use an OEM bolt. Just get two good clean bolts and install with a drop of Loctite.
