cruise42
- Jul 24, 2020
- 20
Rivets...thanks for your insight on ball bearing installation. Guessing it would be best to Iube new sleeve bushinhg before tapping into retainer after bearing is installed. Please confirm. ThxYou can just tap the bearing into the bearing HOC with a hammer. The sleeve will be a snug fit between the axle shaft and the HOC, I suggest you clean the axle shaft smooth with some crocus cloth and lube the shaft and sleeve when installing.
