Toro Myride humming and pulling.
travisy
2021 Toro myride 54 in is humming and pulling to one side.gets worse as I make turns, can cool down and it works better but still hums and pulls.. Help
Auto Doc's
It would help to have the number off the machine tag. Don't assume e know exactly what you have. Machine and engine numbers are important
Most likely, it needs a simple control handle adjustment, or the hydro motor is failing.
VirginiaIron
I have a 2025 Havoc MyRide 77507 with noisy transmissions. The transmissions are noisy even after checking fluids/bleeding air.
My unit has the HydroGear ZD-DUBB-3D5A-2PPX, and my research found this unit to be a better (stronger??) consumer grade unit.
Is the HydroGear ZD-DUBB-3D5A-2PPX transmission any good?
