I have a MX5050 timecutter. My daughter was using it and hit a rut. It knocked the deck off of the hook. They got it back on, but something isn't right. It did not cut even and I got that adjusted, but the deck still isn't right. The right hand scalping wheel is about 1/8" from the front tire. I don't want to make it worse, any heads up on adjustments. I did not see anything on you tube.
