Take it to the dealer and make him fix it.
BlazNT Lawn Pro Joined Apr 26, 2012 Threads 28 Messages 6,973 Jun 14, 2016 / Toro Mx 4260 will not cut at 4.5" as advertised #11 Take it to the dealer and make him fix it.
M Midniteoyl Well-Known Member Joined Jun 14, 2016 Threads 1 Messages 127 Jun 16, 2016 / Toro Mx 4260 will not cut at 4.5" as advertised #12 stamsa said: The deck is level side to side and front to rear. Im not sure what else to do. Thanks for all the help folks! Click to expand... Ok, so the indicator is indicating 4.5", but the blades are actually at 3.5"? Can you not simply adjust (raise) the entire deck so that it matches the indicator?
L logan01 Well-Known Member Joined May 13, 2014 Threads 7 Messages 313 Jun 16, 2016 / Toro Mx 4260 will not cut at 4.5" as advertised #13 stamsa said: The deck is level side to side and front to rear. Im not sure what else to do. Thanks for all the help folks! Click to expand... One other thing as an aside. When you say level all the way around, do you mean truly level or level to that make / model specs?
