I'm in the Houston, Texas area with 1 1/2 acres of St. Augustine grass (plus some unwelcome weeds...)
I'm on flat, but somewhat bumpy ground.
I'm looking at buying a zero turn Toro mower, but which one?
As I'm a geezer with a budget, the SS4260 appeals more to my budget, but perhaps I should get the MX4260.
Opinions?
Thanks!
I'm also available for suggestions on other brands or models.
Thanks again!
You asked for suggestions on other brands or models. It's a Cub Cadet Z Force 48" Commercial and you can buy it for $4199
Specifications
Engine
Engine22 HP Kohler Courage V-Twin OHV
(Displacement) 725cc
(Orientation) Vertical Cylinders2/cast iron sleeve Starting System Electric Lubrication(Filter) Full pressure w/spin-on oil filter Oil Capacity2 qt.Fuel Capacity Single 4.25-gallon tank/single storage pod Forward speed0-8 mph Reverse speed0-4 mph Fuel Gas Ignition Transistor controlled Cooling(System) Air
Transmission
Transmission Dual Hydro-Gear ZT 2800 w/oil reservoir and filter
Chassis
Steering3-way adjustable lap bars Frame Fully welded steel 1.5" x 2.0" tubular section Front Axle Pivoting, steel Tires Front13" x 5.0" - 6.0" (rib)Tires Rear20" x 8" - 10" (turf)Wheel caster(Pivot Bearings) Composite bushing
Dimensions
Deck Size 48"Deck Height Adjustment 1.0" - 4.0" (in .25" increments)Blade Spindle(Construction) Cast aluminum with tapered roller bearings Blade Length17"Blade (Brake Clutch) Ogura GT-1Wheelbase 43"Overall Length70"Width60"Weight722 lbs
General Information
Cutting Width48" triple blade 3-in-1Cutting Height1" - 4"Deck Construction11-gauge fabricated deck, w/7-gauge reinforced top plate Deck Drive Belt driven, KevlarョAnti-Scalping Front roller/ Adjustable nose roller and 2 greasable anti-scalp wheels
(Rear) 4 stripingWarranty3-year/180-hour limitedAlternator12V-15 amp. regulatedBattery275 cca Deck Lift Foot-pedal, spring assisted Seat High-back w/ arm rests and gel suspension Parking Brake Mechanical lever Deck(PTO) Electronic fingertip engagement SeatArm Rest High-back w/ (Type) arm rests and gel suspension Cup holder Standard - in storage poolWarranty3-year/180-hr limited warranty Air Cleaner Replaceable/dual element Wire Automotive-style Deck(Blades) Triple
(Style/System) Floating
(Wash) Patented Smart Jet high-pressure deck washing system Safety Systems Operator presence Standard Return to Neutral; Lap Bar Dampers; Greasable Spindle Bearings; Monitor/Hour Meter; Front Platform Design - Extruded steel Control3-way adjustable lap bars
Hydraulics
Hydraulic Type(Fluid) Rotella Triple Plus 15W40
(Fluid Capacity) 5.0 qt. (2.5 qt. per side including filter) including expansion tank
Oil Filter
