Toro Model 20107 Blade/Brake Clutch Assy
AustinMike
Having a problem with the blade not spinning with enough force when engaged. Bogs down too easy and can't get through easy but thick grass. Is this an adjustment or is the clutch worn out somehow. Is there a clutch replacement package or do I have to figure out which parts are worn out when I tear it down? Thanks for advice and response.
the one i had did that and i tywrapped the flywheel break back and put a kill switch on it ; in MY opinion Toros are notorious for that ;your cable has stretched .:thumbsup:
You do realize that this is a six year old thread and the problem has probably been solved.
well shucks mr revits it came up when i clicked don new posts and with my ptsd and addd i did not even pay attention , however i needed the practice typing
thank you you for your tenacity and endurance:confused2::rolleyes:::confused2:
so wonder why no one responded to his question:thumbsup: .
