AustinMike
Having a problem with the blade not spinning with enough force when engaged. Bogs down too easy and can't get through easy but thick grass. Is this an adjustment or is the clutch worn out somehow. Is there a clutch replacement package or do I have to figure out which parts are worn out when I tear it down? Thanks for advice and response.
