Hi,
Hi all. This is my first post here. I'm hoping that someone can help me out.
I've got a fair amount of ability with repair, but I'm having an issue where the rear wheels won't turn forward when the engine is off. I have removed the transmission cable to observe the behavior of the transmission. With the mower on it's side, when I rotate either wheel, the transmission wants to pivot in the direction of tightening the belt. If I manually hold the transmission in position where the belt is most slack, the wheels will rotate, but when I let go of the transmission it immediately rotates to tighten the belt, thus locking the wheels. I can't see anything that holds the transmission in the loosest position. The attachment mount for the cable stops against the plastic shroud, which prevents it from rotating looser.
In the first image the cable attachment is resting against the plastic shroud, and if held there, the wheels will rotate forward.
In the second photo, I have rotated the wheels forward, thus tightening the belt. You can see that the attachment point has now been pulled away from the shroud.
Thanks.
Kurt
Thanks.
Kurt
