Hi all,
Thought I got a great deal on C List for once but.....Toro Recycler 22 with electric start. model 20374. Seems a little slow to fire up when cold. Runs good, seems powerfull, good cut and bagging. Probably mowed for 20-30
minutes then would not start. Or it would take a long time to start then run for a short while and die again. Let it charge overnight then mowed some more today. Same things happened.
Came across this forum and now I see "Toro" engine is China made and possibly has leaky carb. problems? Engine# 1P65F-2 "TXP 159cc"
Oil Fine, Fresh gas but dont know about previous owners use/maint. Clean filter. Seems like if it had a sheared flywheel key it would run lousy but it seems powerfull and sounds normal to me.
Where would you start if troubleshooting? Seems like if the carb was gummed up it wouldn't run as well as it does (for awhile) am I wrong? Should I assume its bad gas and try cleaning carb? Or would you start with something else?
Seems like not old enough for "lamination" magneto spark maker to go bad?
Thanks for any help to get this thing working properly.
