Just acquired a new walk behind Toro electric Flex Force 60V Max - 21469. I want to remove the upper power head shroud. I cannot find any service manual info on that model. I have removed all of the fasteners I see; four bolts inside the battery compartment and two bolts in the rear. However the upper shroud remains secured, though loose. I just do not see any other attachment points.
I am thinking there could be some friction snaps. I have applied a good amount of pressure but no release, and am afraid of using to much pressure and break it.
Will appreciate some help.
(Actually the reason I want to remove the shroud is because I want to disconnect those stupid headlights, which seem to be so prevalent on new electrics and with no turn-off capability. I do not want to use battery energy powering lights in broad daylight... duh
![Face with symbols on mouth :face_with_symbols_over_mouth: 🤬](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f92c.png)
