J jkp62 Member Nov 5, 2019 #1 My Toro snowblower no longer starts using the electric start- no response from switch. Is anyone familiar with this problem ? The most direct way to start is to check the switch, unless someone has a better suggestion. Thanks
R Romore Well-Known Member Nov 5, 2019 #3 Do you have power at the end of the extension cord? If so replace the starter, they are not repairable.
