Toro 5.5 GTS walk behind ground speed cable replacement difficulty?
huskysizeguy99
  • / Toro 5.5 GTS walk behind ground speed cable replacement difficulty?
The whole assembly with shift knob is like $35, but how big a PITA is it to replace? Please assume I'm NOT mechanically inclined with anything that doesn't require head space and timing, cuz I'm not! Thanks in advance!
model 20464
part: # 76-2712 GROUND SPEED CONTROL CABLE
Sorry, I forgot to include model and part #!
Assume that the C-19 virus has shut down my ESP so unless you provide us with the model and serial numbers for the unit, we don’t know what type of setup you have.
huskysizeguy99
and thanks so much for all the help
