Quick question. My 2005 Toro 460 LX will only move in reverse. When trying to go forward, there is a slipping/ grinding noise in gear box. Not sure what exact cause is. I have opened gear box and confirmed no internal damage. Not sure if the brake disc (pad adjustment)is the issue, the drive belt is going, or clutch collar is worn out.Any info would be appreciated.
