I was cutting grass this evening for about an hour when the mower just shut down. After doing a little looking around I found the 15 amp run fuse had blown. I put another one in and as soon as I turned the key to start it the fuse blew again. It did not even turn over. I checked the battery and the starter and both are fine. No other fuses blown that I can see. I eliminated the fuse to see if I could get it to start and it will turn over,but it seems like it is not getting any fuel. It is a Toro Groundsmaster 455D. Any help would be greatly appreciated.
