Ducke
- Aug 7, 2012
- 2
- 2
I had the govnor gear break on my Toro.
I tore the motor down and cleaned out all the plastic bits washed it out installed a new govnor and re assembled.
The mower starts and will run at slow idle but if I try to move the throttle at all out of slow the motor tries to put a piston out the front end. :frown:
I have read the manual I have tried all the adjustments they say and then some I thought up:mur: but there is no way I can run the motor on anything other then slow.
Anyone have any ideas ???
