ken(toronto)
- Sep 8, 2020
- 1
- 2
Mower will not start. No spark. Traced to solid State Ignition Module. However, tested coil with multi-meter, 3 K ohms; this is supposed to be good.
Could module be bad, even if multi-meter tested it to be supposedly "good" reading? Everything else is fine, grounding, spark plug, flywheel/ignition coil gap.......but no spark!
Ken
Ken
