Toro 20066 just idles
Grassbandit
Did you check the timing/flywheel key?
Since the carb is new, what about the fuel line/filter? (if there's a filter)
Also check the gas cap condition.
Have you check to see if the governor is set properly?
bmorgan
Flywheel key is good
No fuel filter
Surges with the cap off
I'm not going to argue with you, but I will tell anyone else who reads this post that you must mechanically set the governor before setting the RPM's. Good luck, I'm out of here.
bmorgan
Didn't mean to offend you. I traced the actuating arm back to the engine and looked for set screws on the carb mounting plate, but found zilch. Many other engines do have adjustments, I just don't see one for my engine. Can you show me where it is?
