wolfgangamadeus
- Feb 21, 2011
- 3
I have a Toro lawn mower, Model 20584, with (I think - although I'm not sure) a Tecumseh engine 47PH7-212096 (How do you tell if your engine is Tecumseh or Suzuki?). The engine had been surging badly. I just cleaned the carburetor and put the parts to the Toro carburetor kit (gaskets & needle valve) in - and surging is gone. But now engine runs with no surging idles much too fast. Don't know if the carburetor float needs adjusting. I found a Toro engine service manual on line which lists carburetor float drop as 11/16" for engine model 47PD3, but N/A for engines 47PE4 and 47PF5. Since mine is a model 47PH7, I'm not sure precisely what to do about the float drop - or why for two engine models listed in the service manual the drop is listed as "N/A."
Does anyone know what - if anything - the float drop for engine model 47PH7 should be?
Thanks.
Thanks.
