Teds
- Jan 14, 2017
- 82
It is very important that the blade is straight, sharp, and balanced.
The first thing you want to check is the blade track itself. Small differences will affect the quality of the cut in a big way. Shims (washers) of .025" and .035" are used to prevent "half moon" swirls and scalping. Placed as required between the muffler housing and deck. This doesn't affect balance per se. But it does - the blade first needs to be tracking correctly before fine tuning the balance. So check track first.
The Toro people have kindly posted the LawnBoy maintenance manuals that show this, and other techniques. If vibration levels are high on the "D" series engines then they suggest aligning the piston to TDC and then aligning the blade 90° to this. File a line into the end of the crank to maintain this alignment. This makes a big difference. Then - further try it both ways - that is, once the blade is installed perpendicular to the piston at TDC run it up, note the vibration level, shut it down and flip the blade and try it again. For whatever reason a blade may fly or track different.
Here: https://lookup3.toro.com/ttcgateway/acrobat/manuals/lball40.pdf
Proper track and balance will make for a smooth running machine. Check RPM with a tach, it is important that blade tip speed isn't crippled. They were designed for about 3600 on "normal". If you get the track and balance right and the RPM and the rest of it setup well it will reduce fatigue quite a bit and give the high quality cut that LawnBoy was famous for.
