too many pto clutches
emo
I have a 2004 52"advantage scag 18 hp kohler walk behind I live in ct. and mow 3/4 acre on the average once a week from may to sept. I've replaced the pto clutch three times in them 10 yrs. every time it is the electrical parts that go not the disks . I have checked the voltage output and it is 13.5 to14 volts I do the recommended burn in any suggestions emo
mechanic mark
I am using ogura clutches from a scag dealer emo
Question: Do you use water to clean machine after mowing?
If you are hosing machine down after mowing that's your problem, use leaf blower. Also hands on inspect all wiring and connections for corrosion, loose connections, bare wires, wires hanging loose, use tie straps, & check all ground cables and straps making sure they're tight and secure.
emo
no I don't I use air compressor emo
