I believe that I have mowed my yard for the last time this season. Each time after mowing I have blown the mower off with an air hose, but I was wondering about washing it before putting it away for the winter, It's supposed to be sunny today, so I would leave it out to dry well. Any thoughts? 42" Raptor, residential use only.
Shouldnt hurt IF it's dried completely, use a blower & / or an air hose, be sure to get the deck & pulleys really good, (they trap water), then a lube job and an over-spay of WD-40 or something similar Don't forget to check the "vitals" (oil, filters, belts, linkages, tires, blades etc. , either now, or before use next season, RUST NEVER SLEEPS !! .. :thumbsup: OH YEAH ..
NO Pressure Washing !!
I plan on taking the covers off the deck to clean. I plan on a complete lube job and treat the gas with Stabil. Where would you use the WD-40? blades are fairly new, but will check to see if they need sharpened.
I never use water on any of my mowers, just blow them off with leaf blower or air hose & wipe down with a Cal Duster, end of year a good coat of my fav wax.
Which makes next years debris blow off that much easier. And my over 4 year old Z still looks almost new. But that's me.
And I never drain the 100% gas, I just add Seafoam to gas when season is about over. Never an issue.
That's true Boo. How bout you ?
Times like this are the only time my mower gets the hose.
I promise I wasn't playing in the mud, I was just destroying a customer's lawn. :tongue:Darryl, how many times have we told you it's a Lawn-Mower, NOT a MUD-Tractor ..??? you're how old?? N still playin in mud-puddles, .. :laughing:..:laughing:
7394,
You're welcome and I'm looking forward to your modifications and upgrades.
Max
Is that the irate customer from a while back that was very Chitty ??? I don't remember the thread name and all the details ................
Boo,
Somehow I knew you were gonna blow my cover. If you watch any more of the vids, you'll find one of them tells of a 6 yo playing on the mower and man can he do some real acrobatics on a zero turn. He is almost as good on the ole '96 Yardman All Wheel Steer. At least in his active mind anyway. He left the key on that I didn't remember leaving the key in. Either he paid attention to where I place it or I left it in. Either way, it was exactly 20 hours before I noticed it was on and that was more than likely because the battery was totally dead. Wasn't a happy camper at the ole Max, not the child. I'm not sure he is heavy enough for the seat switch to allow him to engage the blades regardless if he'd gotten the engine started because of stick placement.
Now, the real problem I'm having is keeping all those undocumented terrorists, I mean aliens, under the big house until time to clean and hand dry 'Ole Yeller'. lol I know you and I are probably the only two that will get the reference to Ole Yeller. lol
Do me a favor Boo, get our forum to view the vids, subscribe and like to get the channel off the ground. There are so many things on the table for that machine. I've redesigned the dash to make it much more easy for the operator to close the choke while starting the Kawasaki. Problem with placement of the choke cable relative to ignition switch causes the hand to have to leave the ignition switch to push down the cable. The redesign allows the fingers to remain on the switch if desired, tilting the hand to the right side then pushes down the choke cable to keep the engine from flooding. Couple of fellows on my block has a tendency to flood their Kawi due to not moving quickly enough. Mine is just as lean which we all like to get max ponies to the pulleys and run clean to make the engine last longer.
There are deck lift upgrade modifications coming, electric deck lift upgrades coming, oil cooler, hydro coolers, fuel injection upgrade and remember, I always make sure the upgrades can be removed and moved to another unit in the event a person wants to return the unit to factory specifications.
Any help getting Maxs Garaj Mahal youtube channel moving thru subscriptions, likes and shares will help down the road in purchasing materials to do the modifications. Most of the mods I do now for folks I try to make sure they can do with the tools they have on hand or can borrow from the neighbors. lol.
Ok, I have to go get the Undocumented Terrorsts, I mean Aliens back to work. Thanks for calling me out Boo! lmbo
Y'all come to see me, ya heah?
Max
Boo,
I resemble all those words. Appointments only on Thursdays at 12:02 PM. Bride says I have to be out of the house by then if you know what I mean.
Speaking of, I need to get to work on getting some more things done or she may close the Garaj Mahal. Hmmm
Thanks,
Max
