Tire tube
park4019
My Murray rider has 15x600-8 front tires. Side walls are age cracked, tread is good. Local Lowes, & Home Depot, have 15x6x6 tubes. Can I use the 6" tube on the 8" rim ?
Ric
You can go to a lawnmower shop and get the right size for the rim for probably real close to the same price I would think. I don't think a 6" tube will work on an 8" rim.
Carscw
I get mine at tractor supply and walmart.
No a 6 inch tube will not work on a 8 inch rim
park4019
Thanks for the advice, Ric.
