Tire sizes on a CZ 4817
4.10/3.50x5 is approximately 11 inch in diameter. So maybe narrower than the spec'ed tire but same height.
Hmmm. Looks like tire size is not the reason I can't get my deck level. I don't think I can justify replacing the tires just to eliminate checking them before every use. I'll try the ATF trick, and see if that fixes the leaks. And look for other reasons for my deck issues.
Thanks, all, for the info.
4.10 = refers to the width of the tire, measured in inches · 3.50 = refers to the distance from the outside edge of the tire to the outside edge of the rim, in ...
Missing: 4.10/3.5x5 ‎| Show results with: 4.10/3.5x5 for small front tires
well, that was a total waste of time.....
How was that a waste of time? You guys informed me that I had the right size tires. That means that I know what size to get if I decide to buy any. And that I need to look further into what's wrong with my deck.
you don't happen to be an administrator for this site by any chance too, do you . . . . . 🙄
