tire problem
geeball
have a old reel mower need rubber tire put on the steel rim
chance123
Easiest way I have found to do this is to cut/remove the old tire, get a new tire, put it in a microwave for 45 seconds and it will be hot and flexable enough to slip on the rim.
Phil G
You could also try putting some liquid soap on the tyre and rim to help it slide on. They can be a bastard to fit, have fun :smile:
