- Feb 19, 2020
- 119
- 12,783
Yelp lower sometimes is need to keep the mower from being a kidney/back buster. Lots of tree roots and mole holes here and I have to run lower pressures. I had one customer with foam filled tires that I hurt for two after mowing my yard with it while testing a repair for an intermittent problem.One thing to consider on your front tire pressures. There isn’t much weight on the front of a zero turn. The more air that is in the front tires, the more bounce you will get on rough terrain.
