Unless someone has changed all the technology, it is still done by aligning the key seat in the shaft with the key way in the flywheel and placing the flywheel on the shaft with the key inserted and aligned with both. Torque the nut to specs.
#3
Carscw
Did you just take the flywheel off it did you get inside the engine
no I need the corect way to time crankshaft to cam .Can you get it out of time or do you put piston at top dead center on compession stroke like a car engine?Thanks!
#8
Fish
No, you need to talk plainly about what is going on with this......
#9
Carscw
Would have helped right from the start if you would have said you removed the crank or cam.
We can not read your mind or interpret half story's.
I'm still confused with piston at top dead center marks don't line up. But if you line up dots on crank and cam one way but if you turn engine one circle the dot on crank is across the cam on other side. Sorry I don't no what I'm doing. Please help me can't aford a new mower. Thanks Joey!
