Mike88se
- Oct 11, 2013
- 739
I can't figure this one out. 2013 Timemaster I bought as a project. I bought it thinking it only needed carb repair. I took care of the carb and it runs iike a top. The PP system drive system was weak. It would only propel the mower on pavement and then only if I grabbed the cable between the PP lever and the adjustment bracket and pulled hard. I pulled too hard on the cable and broke the lever on the transmission. I installed a new transmission, new drive cable, and new belts. That helped a little. Now it will propel on pavement just by pushing down on the PP handle. The gears on the ends of the axle are good. The teeth on the wheels are good. The spring that holds tension on the belt is good. I can't see anything that would keep this thing from working.
