Timemaster 30 - 2019 model year - hunting like crazy
mpavia42
Hi there! I’ve been having an issue with my toro timemaster 30 that I just can’t figure out. It’s hunting and popping when hot. No decrease in performance when running, but when idle it’s just constantly hunting and backfiring. Changed the spark plug, fuel filter, only use good gas, took the carb off and did the best I can to clean it - no change. Any ideas?
Tiger Small Engine
Sounds like pilot (idle) jet is blocked, or possible intake air leak. Remove carburetor, completely take apart, thoroughly clean, replace.
Flush out the fuel tank and install new filter and hose. Solid fuel flow AT carb inlet. Drain tank into a glass jar for verification.
Buy a cheap hot plate electric burner and a cheap pot. Strip the carb down separating all plastic/rubber parts out. Boil the carb with pH neutral soap and water for 45 minutes. Dawn is alkaline so don't use it. It will oxidize the aluminum body. Forget the ultrasonic cleaners. Waste of time and money. By the time the water gets hot it is shutting off LOL. Blow carb out with compressed air. Make sure jets are open with fishing line or smaller than hole bread tie wire with the plastic stripped off the wire.
mpavia42
Yes that's the last thing I did - all clean. Which one is the idle jet? When I took the carb off I thought I hit every hole. And thanks for the tips! Is there anything else it could be? Fuel filter shows full of fuel so I doubt it's a line restriction.
Only thing a full filter means is that it is full. Flowing fuel is totally unknown. Old Jeep story. Had a horizontal hard line get plugged up with 40 years of dirt and a poor gas cap. My filter was full. Even would squirt out of the accelerator pump into the carb venturies. Though I had fuel??? Engine would starve out on the highway. Checked for flow and found a dirt plug in that hard line. Once flowing she ran great again.
Make sure you have a solid flow AT the carb inlet.
mpavia42
Good point - will pull that hose off and see.
Double check the float level. Prime cause of lean mixture on Briggs carbs.
mpavia42
Update - seems it was blocked fuel flow, pulled the line off and ran a wire through the fuel tank outlet. Didn't really see anything, but problem gone. Will take the time to remove tank and flush it out. Probably a bug fell in there or something. Thanks everyone for your help!
