BlazNT,
Just a follow up. I followed your input in our last thread. Thanks. Searched high and low for a trigger oil can with a long enough hose. No luck. Bought a pint bottle and about 16" of clear tubing. Duct taped it to nozzle. First time I went under mower to remove fill cap. It sucked! So I found a longer Allen wrench and used the hole with the air tube in it. Was tedious buy was able loosen and tighten repeatedly. After two attempts of purging, I was done. Ran forward and backwards with out issue. Cut my.lawn finally! Thanks again for your input.
Bud
