tiller question
ghost1
I replaced engine on a 1999 Yard Machine tiller and now the transmission belt doesn't have enough slack to allow it to be moved from neutral to a drive/tine gear even with the idler/tension pulley not installed. I've moved engine to allow as much slack as possible. It calls for 1/2 x 58 in. belt. Would increasing belt size remedy and if so, how is it determined what size to get?
BlazNT
I would say you put the wrong pulley back on. Maybe from the new to you engine?
ghost1
I used pulley off of original engine
BlazNT
To measure, what you need take is a 1/2 nylon rope and feed it through all the pulleys the way the belt goes. Mark the length and then measure it.
