I am new to the forum, and appreciate having contacts to discuss with.
I have a 2013 Tiger Cub. The left hydraulic motor leaks fluid, it appears to be a seal and not a hose connection, but I am not positive. The leak is not heavy, the motor functions correctly. I would like to stop the leak of course.
If I end up needing to rebuild it, is there any good instructions for doing so? I did see a youtube video on a motor rebuild, I think it was on a Cub Cadet but looked to be fairly straightforward. The motor is a PG-1KCC-DY1X. I was looking underneath, I dont see a tensioner to remove the belt? Also, do the pulleys require a puller to remove?
Thanks for your comments!
Tom
Tom
