Tiger Cub engine sputtering
Jskyking
I have a TC with an 18hp Kawasaki engine. It runs like a champ on the left tank and sputters like a dog in the right. I suspect bad fuel, though I used fuel from the same can in both tanks. Does it have two fuel filters? It’s possible it could have bad gas in the right tank, so I can start by draining the tank and checking the hose for wear and tear.
Planning on diving into the problem tomorrow. Hopefully, someone has a similar story and a fix.
Thanks
Jt
Take the cap off then blow backwards up the fuel line.
Problem goes away for a while = debris plugging the fuel outlet or the tap.
