Tiger Cat 61” engine
my 61” Tiger Cat has a woeful 27hp Kohler on it. Runs terrible, we have done coils, carbs, governors, etc just doesnt want to perform. found a 25hp Briggs that will fit the mower, question is —— is 25hp enough for the 61” deck or should i keep looking for 28-35hp motor?? any help appreciated. mower is a 2012 or 13 model.
The CH740 Kohler Command Pro was overrated for HP. They eventually changed the rating to 25hp. Do your research thoroughly before pulling the trigger on the Briggs. There are many factors to consider. Wiring can be modified, but crankshaft must be proper Diameter and length to accommodate PTO - idlers - etc.
Also will Briggs still be providing parts when you need them. Done ran into one case this Late Summewr where a less than two old Briggs engine where I could not even get an ignition coil for it.
