Tiger cat 48"
Blah114a
Hi, I'm new here. Does the 48" tiger cat have a velocity deck? I'm speaking of a new mower. A dealer told me it does not. I'm welcoming a second opinion. Please, thanks
"Powerful engines and a tough dual pump and wheel motor drive system ensure dependable performance, year after year. Equipped with a Velocity Plus™ cutter deck, this mower will tame the tallest grass and leave it looking smooth and professionally manicured."
http://www.scag.com/tigercat.html
Super easy to tell, if the deck has a beveled front then its a Velocity deck. If the has the hard 90 degree angle then its a standard cutter deck. Check out some pictures and you will see what I mean! The tiger cat should have the velocity deck stock!
Tiger Cat, Cheetah and Turf Tiger all have Velocity decks. The machines below the Tiger Cat level have a standard deck that is similar to the Advantage decks that were on older Tiger Cubs thru Turf Tigers, however they are not Advantage decks. My 2007 Tiger Cub came with a Velocity deck.
I have never seen a Tiger Cat with out a Velocity Deck. I have three with 52" decks and they are all beast when it comes to cutting tall grass. As far as I am concerned a Tiger Cat is as good as it gets to cut grass. If I thought anything was better I would own it.
