I started this nearly three years ago. How to design a front loader for a garden tractor? Offsetting 200 pounds in front of a riding mower or garden tractor is a lot of weight. The new design incorporates several innovations. As the scoop is lifted it also tilts back about 40 degrees all in one motion. This centers the weight in the scoop. Reduces the chance of spilling mulch as you transport it around the yard. It also moves the scoop as close as possible to the front end reducing the offset weight as it lifts to about 12 inches above the ground. The scoop is a clam shell design. As the bottom move forward to open it gets higher off the ground instead of lower. All this allows you to drive right up onto the mulch bed and dump 4 to 5 cubic feet of mulch. Without this much height the pile would be so tall you couldn't close the scoop without grabbing back some of the mulch. How does it lift all this weight? Well the truth is it lifts nearly nothing at all. The servo drive is rated for 660 pounds of lift. The scoop with all the hardware weights in at about one hundred pounds. Then add in a hundred pounds of mulch. Above the scoop are four linear constant energy springs. As they uncoil and recoil they produce 150 pounds of lifting force. So the scoop is actually negative fifty pounds when it is empty. Meaning it wants to stay up not down. The servo must force it back to the ground to be loaded. But filled with a hundred pounds of mulch it is positive fifty pounds. Which means it only takes fifty pounds of force the lift a hundred pound of mulch. I will soon be introducing the scoop for sale to the commercial landscaping market. Putting down mulch cost about $35.00 a yard to have someone do it. Moving four yards an hour works out to $140.00 an hour with this attachment or $1100,00 in an eight hour day. All without a shovel, pitch fork or wheel barrow. Ron 804.536-1213
