dixiechile
- Jul 16, 2018
- 3
Just finished putting in a piston and ring kit and got everything to the point the engine will crank but start. discovered the choke linkage is working as it should but the throttle linkage doesn't move when the throttle is brought foward or backward on the dash. Have just one red spring but can figure which holes it needs to go into based on the diagrams in the Kohler Courage SV470-SV620 Service Manual Mutliple diagrams for different max RPM engines. and I have looked all over the internet trying to find the max RPMs for the SV610-3213 engine to no avail. I need specfic diagram and instructions on how to asemble and adjust this carburator. Any help is appreciated
