Throttle down
motime
My 145 came with the house I bought. I always throttle down and let it run for a minute or so before turning off. Good or bad for engine? Thanks
7394
That is in the Kawasaki engine manual as proper shut down procedure. I think Kaw has a clue about this.
As well as letting it warm up a bit & only throttle to almost 1/2, then engage the blades, then open throttle WFO, it is easier on the blade clutch pack for engagement.
I mean you don't floor your truck/ car or whatever stick shift, then engage the clutch. Right ?
motime
Thanks
If it's a splash lube engine, BAD. Even with full pressure lube, why risk it. Rev the sucker. Floor it, wait, not supposed to do that. LOL Joking of course.
motime
Thanks. It's a B&S 22 hp. Not sure if that's a splash lube engine.
