Throttle body linkage on a 10 HP OHC Briggs
Sugar Bear
The starter rope handle has been pulled violently out of my hand from time to time on starts since about hour 10 of the roughly 150 hours I have put on the engine over 6 years.
I guess this would indicate the flywheel key has been a little out since the beginning???
Perhaps either the White Oak I just cut. The hardest wood I have cut since owning the saw and or the backfire sent the key over the top?
Eah????
Remember when I said we needed a good picture of what you are seeing to help you? Finally got the last part of your masterpiece. How much money can I pull on a bad key? Don’t need a puller, there are many videos on the web to show you how to do it. Not going to tell you how I do it, because it is too easy to damage something expensive if you make a mistake.
