Throttle assembly
RJH
I had to replace my drive belt on a 07 LT1045 in the process I broke the bolt off as Cub Cadet in assembling the mower used alot of red locktite on the bolt. I had to take the motor off to take it to a machine shop to get the broken bolt out. Yhat is done but I am having trouble reassebling the throttle assembly. Can some one help as to how the throttle cable attaches.
EngineMan
Not sure if this will help you out...
B is where the cable goes from the throttle cable.
F goes to throttle on the carb.
RJH
Thanks for the feedback. The throttle assembly I have looks a little different but also very simular. Looking at the assembly I see where the cable goes to the governor but can't figure out how to attach the throttle control to both governor and sprrd control.
EngineMan
Find this in the manual.
RJH
Engine man,
Thanks very much. That is the best diagram I have see yet and is very helpful.
