SeniorCitizen
- Aug 28, 2010
- 132
- 2,183
I've been mostly a DIY type and so changing oil in our vehicles usually isn't any big deal. Well, until this time. I did say mostly because I did take my wife's car to my dealer the last oil change which is very rare.
So yesterday morning, according to the car's DIC, it was time for another oil change for this vehicle and it was my turn to pull wrenches. And did I ever pull, which is is the subject of the link provided.
Do you know the torque specifications of the oil drain plug on your vehicles. Well evidently the dealer's mechanic doesn't either on the subject car. So I called the service manager to get the information and he looked it up. Would you believe 18 ft. lbs.
Now, let me tell you the story about how this old man that has Pop Eye arms got this drain plug loose. The 15 mm combination wrench wouldn't touch it with an estimated 30-40 lbs. torque. Any good mechanic knows how to breed two combination wrenches for double the length and torque. No such luck on this plug. Being under the car on my back and working with what I had space for, I finally got it loose by opening the jaws on a 14" pipe wrench far enough to put the jaws on the 15 mm wrench body at 90°.
Ever hear of stripped threads on an oil pan and have to deal with that ? Not fun is it. This dealer got lucky on this one and I'd bet the tech is wishing good records weren't available. The service mgr.looked it up and knows which tech did the oil change and when.
http://aoca.org/pdf/drain_plug_torque_2011.pdf
