I looked at several places and kept coming up with that same part number (595660). And i can't remember ever getting any bad info from Greentree. So when they listed this as being over 8", I was stumped. Trying to remember if I'd ever seen one of these covers (with the primer hole) being bigger than any others (for this type of briggs)Looks like the 09P602-0019-F1 is using the 595660 cover. But the serial number that you originally posted is coming back to a different engine than the model you posted. But I have seen the Briggs serial number search come up with some weird results depending on how the serial number is input. All numbers together give one model. Spacing between certain numbers will give another.
I didn't want to get into a situation by ordering the wrong part over a slight mistake. Those plastic pieces almost never get used.
