Some one said the color of the wires are different on wiring diagrams. The kill wire coming off the DSAI module is white and when it goes into the connector its not white coming out going to the ignition switch. Anyway is this the wire that goes to the M terminal on the ignition switch? I think I have what I need to test the DSAI module. I have a spark tester and a digital multi-meter. I will study the testing directions again and try to test it. Thanks for any info on kill wire going to the M on switch or what wire is suppose to go there. Thanks
