The frozen whelk thread
jpokerwinski
I hope someone could give me some insight or knowledge on how to get a frozen rear wheel off a garden tractor. Specifically it is a. Old MTD .
I have tried everything from PB Blaster to heat to pounding it. Nothing no budge.
My next try would be to get an air chisel to the back of it. But I wanted to see if anybody had any other ideas?
Jim
johniii
Are you hitting it from behind the wheel? You may need a bigger hammer?
johniii
Does it have just one nut on the wheel? You need a 5 pound mini sledgehammer, something bigger than 2 pounds. Hit the wheel dead on without a pipe. Spin the wheel and hit again.
jpokerwinski
The wheel has the attached type hub. One bolt and a washer hold the wheel on. Your saying to hit the wheel with a 5 pound in the front?
jpokerwinski
Also most places around here sell 4 pound sledge. Harbour freight has a 5 pound dead blow but it has a soft face
johniii
Hit it from the back it doesn't have to be 5 pounds, it's what I would use. Maybe try wally world or a hardware store. Pass on the dead blow, H.F. has 4 pound mini sledgehammer I believe.
jpokerwinski
I used to have a 5 pound but it flew off the handle and damn near killed my wife😂😂😂😂
jpokerwinski
I am not sure I can get a good hit in the back without some sort of pipe?
