Is anyone else bothered by crab grass? I found a website that gives me some good info on how to stop it from growing. It says, maddeningly enough, that the best way is to have a heathly luxuriant lawn, as crab grass will take hold if you have bare spots, etc.
It's suggestion for killing it, once you have it, is "the use of pre-emergence herbicides." Apparently you need to use these in the spring, before the temperature reaches a sustained 55 F.
My problem is, we aren't allowed to use pesticides in our city. Are herbicides the same as pesticides?
