PTmowerMech
- Apr 16, 2018
- Threads
- 443
- 3,421
After reading what you wrote in the "echo carb kit" thread, I'm scared to take a chainsaw carb apart. lol
CS-305. Customer says it just needs a primer. Difference being, this customer doesn't seem to be the kind to use his saw once a year. This one looks used regularly.
None the less, after replacing the primer, it'll only run until the fuel from the priming is gone. Not to mention, the primer bulb won't fill up. It sucks some fuel. But very little. I've filled the tank with fresh mix and cleaned out the filter.
There's limiters on this carb, inset like I've never seen.
