amen to that.To get power to the blue wire it is a long & torturous path.
One more saftey to check for the blades. Then the ignition switch. Didn't realize there was one for the parking brake. Thanks for the blow by blow on electricity flow. Will come in handy. But now I have to jump on my Walker and mow the lawn. :frown:Starting at the fuse power goes to the B terminal on the ign switch ( battery power )
From these it goes to the S = Start terminal
Then to the PTO switch, through that if it is turned off
Then to the hand brake safety switch which if it is working will pass voltage through to the blue wire and energise the starter solenoid.
If any link in the chain fails, then you ain't going anywhere.
So now you have to put on the deer stalker, grab the magnifier and do some investigating.
