johnbell47
At this point, I'm just going to go around any broken splice or blown diode and run a new wire and a new diode, That entire wire harness is wrapped up in some very nice yellow netting that looks substantial. Not going to go in there and make a mess of that. I am a neat freak so the wire will be yellow, it will be wire tied well and will look almost factory. I'm old, I have plenty of time and not much to do! Thank you for your able assistance!Okay sounds you got narrowed to the area that causing the problem. Now it is just a matter of finding what in that area that has failed. Be it a bad splice, broken wire, or a failed diode. Just I knew where diode was but I have never worked on one these diesel units.
