dandonnell
I have this older generator with the HM100 10HP engine that I am having issues with it starting/running. This is a used generator (1999) with very few hours I received for free because of the plastic fuel tank split issue on these Devilbiss 5250 generators. So i replaced tank and tried starting and it initially started well but the engine surged or hunted so I assumed it was carburetor since this unit sat for a few years with old gas. So I let it sit for a few more years and now i took carburetor off and cleaned out fairly well but didn't solve problem in fact now it is harder to start. So I ordered one of the aftermarket carbs on Amazon for $12 figuring what could I loose. That carb didn't work either so now it only would start quickly on choke but would either surge or stall out and not remain running. The carb wasn't exactly like the old so I thought let me rebuild the old carb with an OE Tecumseh kit. So got the kit and changed out emulsion tube seals, float valve seat and needle, bowl gasket and jet gasket. Float was plastic one with no leaks so I was able to re-use. Cleans all the main jet orifices and passages, made sure carb cleaner would spray through all passages under welch plugs but didn't remove them. When I tried to start with the old rebuilt carb it acted the exact same as the new aftermarket carb, would start on choke but would stall after a couple seconds. The only thing I haven't changed is the carb to manifold gasket although it looked good. Could I be getting enough of a leak there to cause this condition? I would think it would at least keep running with a leak but would run rough or erratic. Any other suggestion?
