I pulled the carb and decided not to clean it since it had some corrosion. I installed a new carb and the surging is gone and the motor idles fine, but it is still missing when I advance the throttle. It's sort of a random missing, a popping sound. This motor has a solid state ignition module. The plug is new. Any ideas on what I should check?
Thanks all.
Thanks all.
